A6 C6 3.0 tdi Quattro
krzycho40
Post autor: krzycho40 » 10 maja 2013, 16:46
Witam jak pisałem w powitaniu ,przesiadka z "mesia" na A6 i żałuję tylko że tak pózno oto ona:
Typ handlowy: 4F20LL Data produkcji: 2007-10-18
1 0F3 L KRS Fuel system for diesel engine
2 0G7 L GES Tiptronic
3 0HP L AED Vehicle class differentiation 4F0
4 0JM L GKV Weight category front axle weight range 12
5 0LW L SIZ Special plates/stickers/ safety certificates for Germany
6 0M5 L KBV Fuel tank
7 0N5 L HIA Standard rear axle
8 0TD L ZFM Front and rear floor mats
9 0VC L BTA Information kit in German
10 0W1 L AKZ Label for central electric German-speaking countries
11 0YH L GKH Weight range 8 installation control only, no requirement forecast
12 1BA L DAE Standard suspension/shock absorption
13 1C1 L FRO Antifreeze up to -25 degree celsius tolerance up to -30 degree C
14 1D0 L AHV Without trailer hitch
15 1EX L TYP Special identification plate for EC
16 1KD L BAH Disc brakes, rear
17 1LG L BAV Disc brakes, front
18 1N3 L LEN Speed-related variable steering assist (Servotronic)
19 1PA L ABR Standard wheel bolts
20 1S1 L BOW Tool kit and jack
21 1SA L TWU Without additional engine guard
22 1T3 L VBK First aid kit with warning triangle
23 1VH L TWL Installation parts for six-cylinder engine
24 1X1 L ATA Four wheel drive
25 1Z2 L KRM Increase in initial standard fuel filling
26 2C5 L LSS Axial and vertical adjustable steering column
27 2D0 L CWV Without cd enhancing underbody panel
28 2G0 L EBB Without insert for the filling up of fuel
29 2K1 L SFS Reinforced bumpers
30 2KR L SAU Labels/plates in English and German
31 2WA L ZBR Without additional tires
32 2Z1 L TYZ Type sign at rear and "Quattro" nameplates respectively
33 2ZQ E LRA Leather trimmed multi-function steering wheel for air bag system
34 3B4 L ZKV Child seat anchor for child seat system ISOFIX
35 3F4 P RER Spare wheel with original equipment tire
36 3FA L DEI Without roof insert (standard roof)
37 3G0 L KSI Without child seat anchor front (ISOFIX)
38 3GA L LBH Without cargo area
39 3L3 L SIE Manual height adjustment for front seats
40 3M3 L SZL Passenger car design
41 3NZ L HIS Rear seat bench unsplit, backrest split folding
42 3S0 L DAR Without roof rails/roof load rack
43 3X0 L DLS Without load-through provision
44 3Y0 L SSR Without roll-up sun screen
45 4A3 P SIH Seat heater for front seats separately controlled
46 4D0 L KMS Without seat ventilation/massage seat
47 4E0 L SDH Tailgate/trunk lid unlocking from outside
48 4GH L WSS Windshield in heat-insulating glass with sunshield
49 4H3 L KDS Manual child lock
50 4K4 L TKV Radio remote controlled central locking
51 4KC L SSH Side and rear windows in heat-insulatingglass
52 4L2 L IRS Dipping breakaway interior rear view mirror
53 4R4 L FEH Power windows with comfort operation andcircuit breaker
54 4UE L AIB Air bag for driver and front seat passenger
55 4W0 L KBO Without cassette and CD storage unit
56 4X3 L SAB Side air bag front with curtain air bag
57 4Y0 L VSS Without storage compartment/safe box
58 4ZB L ZIE Bright moldings
59 5A4 L GRV Trunk lining (design 1)
60 5C0 L KSA Without special body measures
61 5D7 L TRF Carrier frequency 868 MHz without panic button
62 5J0 L HES Without rear spoiler
63 5K5 L LAC Transit coating film with additional transport protection
measures
64 5NC L FHE Standard tailgate stay
65 5P0 L AFS W/o mounting fixture for oxygen bottle
66 5SL L ASL Left exterior mirror: aspherical
67 5TD L EIH Decorative aluminum inserts
68 5XC L SON Sun visors with illuminated vanity mirror on driver's and front
seat passenger's side
69 6E3 P MAS Front center armrest
70 6FA L BBO Components without special surface appearance
71 6M0 L GPS Without tie down straps/net/pocket
72 6NJ L HIM Standard molded headlining
73 6SS L KBB Luggage compartment floor covering
74 6TS L ASR Right exterior mirror: aspherical, large viewing field
75 6U0 L ZTD Without additional seals outside
76 6V1 L HEB Rear trim panel (ECE)
77 6W6 L KZV Front license plate bracket
78 6XD L ASE Exterior mirrors: electrically adjustable/heated
79 7A6 P CDW CD player and CD changer
80 7AA L EDW Electronic vehicle immobilization device
81 7B0 L STD Without socket
82 7F9 L SAG Plastic/leather gearshift knob/handle
83 7GG L AGM Emission standard EU4 DPF
84 7K0 L RDK Without tire pressure warning light
85 7M1 L EIL Scuff plates in door apertures with metal inserts
86 7P0 L LOR Without lumbar support in seat backrests
87 7Q9 P NAV Navigation system
88 7QB P CDR CD ROM (Germany)
89 7X4 E EPH Park distance control, front and rear
90 7Y0 L SPU Without lane change assistant
91 8DP P RAO Radio "LOW II"
92 8ED P HSW Bi-functional headlight with gas discharge lamp, for driving on
the right
93 8GV L GEN Alternator 180 A
94 8K9 P FLS Separate daytime running lights with low beam assistant and
"Coming Home" function
95 8Q3 P LWR Automatic headlight-range adjustment dynamic (self-adjusting
while driving)
96 8SK P SBR Taillight assemblies with diodes (LED)
97 8T1 P GRA Cruise control system (CCS)
98 8TC P NEL Rear fog light for driving on the right
99 8X1 P SWR Headlight washer system
100 8Z5 L MKU Not hot country
101 9AK L HKA Climatronic with impact pressure control free of cfc
102 9LA L RTK Without rotating emergency lights
103 9M0 L ZUH Without auxiliary/parking heater
104 9P3 L SGK Seat belt reminder, electric contact in buckle
105 9Q2 P MFA Multi-function display/on-board computerwith check control
106 9VD E LSE Speaker (active)
107 9ZF P VTV Mobile phone preparation with hands-freespeaking system
108 A00 L SAH No self-collection
109 A51 L HER Audi AG
110 A8S I AUS Standard equipment
111 AQ0 L QUA Standard-production quality
112 B01 L TPL Type approval Germany
113 B0A L BLB Component parts set without country-specific design requirement
114 C17 E COC Operating permit, alteration
115 C9P P RAD Cast alloy wheels 7.5J x 16
116 D1D L MOT 6-cyl. turbo dies. eng. 3.0 L/171 kW 24VV6 TDI, common rail
base engine is T41
117 E0A L AAU No special edition
118 F0A L FZS No special purpose vehicle, standard equipment
119 FA0 L SVO Control of standard production
120 FC0 L IND Without customized installation
121 FM0 L MDS Basic equipment variant
122 FQ0 L QGM Standard production wheels
123 G0R I GSP 6-speed automatic transmission for four-wheel drive vehicle
124 GZ0 L EST Manually operated doors
125 HS0 L REI Tires 225/55 R16 99Y x1
126 J0Z L BAT Battery 520 A (110 Ah)
127 K8B I KAR Notchback
128 L0L L LEA Left-hand drive vehicle
129 N2C L SIB Fabric seat covering
130 NT0 L TSP Transit coating (type 1)
131 NY0 L BGK Standard battery/alternator capacity
132 PER G Spare wheel with 16 full-size tyre
133 PI3 G Informaèní systÊm øidièe
134 PNR G Navigaèní systÊm vèetnÏ MMI basic plus
135 PRS G Cast aluminium alloy wheels, 7.5Jx16, 6-spoke Structure design,
with 225/55 R 16 tyres
136 PT5 G Pøíprava pro mobilní telefon (Bluetooth)s loketní opÏrkou
137 Q1A L VOS Standard front seats
138 QE0 L ALG Without tray areas package/box
139 QF0 L BDH Without receiver (car phone)
140 QH0 L SPR Without voice control
141 QQ1 P LCP With additional lights (interior lighting)
142 QV0 L TVE W/o TV reception/digital radio reception
143 T41 I GMO 6-cylinder diesel engine 3.0 L unit 059.D
144 U2A P INS Instrument insert with km/h speedometer,radio-controlled clock,
tachometer and trip odometer
145 V0A L REL Tires w/o specification of tire brand
146 VC0 L GRT W/o remote-controlled garage door opener
147 VX0 L SPA Without hands-free system
148 VY0 L GAS Without danger alarm system
149 WDC G Business package
150 X0A G National sales program Germany
jak widać standard lecz mam nadzieję że z pomocą forumowiczów coś wymodzę ps. fotki pózniej sorki(muszę je poprawić)
[ Dodano: 2013-05-10, 17:38 ]
I zdjęcia......http://www.fotosik.pl/pokaz_obrazek/925 ... 278c7.html
http://www.fotosik.pl/pokaz_obrazek/8a2 ... d1d08.html
http://www.fotosik.pl/pokaz_obrazek/5a0 ... 4d9d0.html
http://www.fotosik.pl/pokaz_obrazek/54f ... 5e664.html
http://www.fotosik.pl/pokaz_obrazek/c42 ... ca55b.html
http://www.fotosik.pl/pokaz_obrazek/854 ... ece22.html
http://www.fotosik.pl/pokaz_obrazek/371 ... 8505d.html
Audi A7 Klub
Post autor: Audi A7 Klub » 10 maja 2013, 18:05
Kolorek taki jak mój <okok> Wyposażenie trochę ubogie, mechanicznie ma jak najdłużej służyć. Zawsze można coś doposażyć. A ile ma na budziku? Miliona km życzę!
krzycho40
Post autor: krzycho40 » 10 maja 2013, 21:57
Sprawdzone 200000 książka (i dzięki poleceniu z forum po vin-ie)wolę prawdziwe 200 niż 170 na budziku a w pamięci jeszcze 200 :|
[ Dodano: 2013-05-10, 23:15 ]
reszta fotek
http://www.fotosik.pl/pokaz_obrazek/efb ... eef94.html
http://www.fotosik.pl/pokaz_obrazek/710 ... 107da.html
http://www.fotosik.pl/pokaz_obrazek/e73 ... e62b5.html
http://www.fotosik.pl/pokaz_obrazek/0b3 ... 233f3.html
http://www.fotosik.pl/pokaz_obrazek/c52 ... 55462.html
i jeszcze prośba o radę co do modów chcę zmienić mmi na 2g,dołożyć kamerę cofania,wsadzić 18 na lato,czy mogę podłączyć telefon,spolszczyć i navi .....z góry dzięki za fachowe porady <luzik>
Audi A7 Klub
Post autor: Audi A7 Klub » 12 maja 2013, 12:07
krzycho40, Wszystko jest na forum kolego. Co mogę napisać to jeżeli chcesz zmienić na mmi2g to Ci panowie pomogą : www.navitechnik.pl Co do 18 polecam Ci z rs6 (wejdÂź na mój profil) na początku miałem właśnie takie i pasują one idealnie. Co do kamerki to najpierw musisz doposażyć autko w mmi2g bo bez tego ani rusz z kamerką
Audi A7 Klub
Post autor: Audi A7 Klub » 12 maja 2013, 19:34
jakos78, Moje były oryginalne z tego modelu :p ;p
Audi A7 Klub
Post autor: Audi A7 Klub » 12 maja 2013, 20:45
jakos78 pisze:ktoś już to przed tobą zmienił
Malo poinformowany jesteś <luzik> One były w wyposażeniu już. W kodach wyposażenia one już były <okok>
Audi A7 Klub
Post autor: Audi A7 Klub » 12 maja 2013, 21:12
Dobra kończmy ten OT w wątku kolegi <okok>
