Do tego zauważyłem, że skaczą wolne obroty między 900 a 1100 obr/min. Po skasowaniu błędów przez 300 km ok potem z powrotem kontrolka...Address 01: Engine
2 Faults Found:
008583 - Bank 1; System too Lean at Idle
P2187 - 004 - No Signal/Communication - MIL ON
Freeze Frame:
Fault Status: 11100100
Fault Priority: 0
Fault Frequency: 8
Mileage: 198590 km
Time Indication: 0
Date: 2012.02.07
Time: 21:00:58
Freeze Frame:
RPM: 771 /min
Load: 14.5 %
Speed: 0.0 km/h
Temperature: 75.0∞C
Temperature: 0.0∞C
Absolute Pres.: 1020.0 mbar
Voltage: 13.462 V
001287 - Idle Control System RPM: Higher than Expected.
P0507 - 001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 0
Fault Frequency: 2
Mileage: 198737 km
Time Indication: 0
Date: 2012.02.11
Time: 16:20:42
Freeze Frame:
RPM: 917 /min
Load: 14.5 %
Speed: 0.0 km/h
Temperature: 76.0∞C
Temperature: 15.0∞C
Absolute Pres.: 1010.0 mbar
Voltage: 13.589 V
Readiness: 0000 0000
Ma ktoś jakiś pomysł?
