Audi A6 C5 2003 163, MULTITRONIC
Pół roku temu wymieniona skrzynia
Miesiąc temu wymieniony olej.
Teraz samochód zaczął mi szarpać przy ruszaniu
Kod: Zaznacz cały
VAG-COM Version: Release 311.2-N
Chassis Type: 4B - Audi A6 C5
Scan: 01,02,03,06,08,15,16,17,18,22,34,35,36,37,45,55,56,57,65,67,75,76,77
Address 01 -------------------------------------------------------
Controller: 8E0 907 401 P
Component: 2.5l/4VTEDC G000AG D14
Coding: 01017
Shop #: WSC 02325
00006059 130 106JC150_1.V79964209381
2 Znalezione:
00542 - Needle lift Sensor (G80)
30-10 - Open or Short to B+ - Intermittent
01375 - Valves for Engine Mounting: Stage 1
38-10 - Output won't Switch or Short to B+ - Intermittent
Readiness: N/A
Address 02 -------------------------------------------------------
Controller: 4B1 910 155 J
Component: V30 01J 2.5lTDI RdW 3400
Coding: 00001
Shop #: WSC 70230
1 Błąd Zapis.:
18161 - Tiptronic Switch (F189): Implausible Signal
P1753 - 35-10 - - - Intermittent
Address 03 -------------------------------------------------------
Controller: 4B0 614 517 G
Component: ABS/ESP front 1728
Coding: 06399
Shop #: WSC 02325
Nie ma błędów 🙂 .
Address 08 -------------------------------------------------------
Controller: 4B0 820 043 AJ
Component: A6-Klimavollautomat 0105
Coding: 00103
Shop #: WSC 02325
Nie ma błędów 🙂 .
Skipping Address 15-Airbags
Address 35 -------------------------------------------------------
Controller: 4B0 962 258 L
Component: Zentralverriegelung D37
Coding: 06721
Shop #: WSC 47309
4 Znalezione:
01561 - Left Rear Door
59-10 - Can't Unlock - Intermittent
01562 - Right Rear Door
61-10 - Won't De-Safe - Intermittent
Address 37 -------------------------------------------------------
Controller: 4B0 919 887 E
Component: BNS 4.2 H05 BNO 0020
Nie ma błędów 🙂 .
Address 56 -------------------------------------------------------
Controller: 4B0 035 186 G
Component: concert II GRO 0008
Coding: 00011
Shop #: WSC 02325
Nie ma błędów 🙂 .
End -------------------------------------------------------
