kodowanie wtryskiwaczy
witam zabieram sie za wymiane wtryskiwaczy w 3.0 bmk czy konieczne jest kodowanie po wymianie czy po 1000km same sie zakoduja? jezeli trzeba to jak to zrobic vcdsem
z gory dzieki:)
kamil666
- Imię: Kamil
- Silnik: 2.8 FSI 220KM
The IMA-ISA values need to be adapted when:
One or more injection valves have been replaced. Make sure not to adjust the valves which have not been changed!
The engine control module has been replaced.
Do NOT adapt these values when you did not replace one of the above parts, also not for training or demonstration purposes.
The adjustment code can be found on the injector itself, it is a 7-digit value and does only use the following chars: 1,2,3,4,5,6,7,8,A,B,C,D,E,F,G,H,K,L,M,N,O,P,R,S,T,U,V,W,X,Y,Z. A value of AAAAAAA is also not valid.
Prerequisites:
Ignition ON
Engine OFF
[Select]
[01 - Engine]
[Adaptation - 10]
Channel 071: IMA-ISA Value for Cylinder 1
Channel 072: IMA-ISA Value for Cylinder 2
Channel 073: IMA-ISA Value for Cylinder 3
Channel 074: IMA-ISA Value for Cylinder 4
Channel 075: IMA-ISA Value for Cylinder 5
Channel 076: IMA-ISA Value for Cylinder 6
[Test]
[Save]
[Done, Go Back]
Switch Ignition OFF, wait 10 seconds and switch Ignition ON again. The values should be saved now, please verify them by double checking the adaptation values.
Prerequisites:
Ignition ON
Engine OFF
[Select]
[01 - Engine]
[Adaptation - 10]
[Test]
[Save]
[Done, Go Back]
