[c5] xenony
[c5] xenony
Witam wszystkich mam pytanko czy we wszyskiech c5 które mają soczewki i spryskiwacze reflektorów były montowane xenony ? ewentualnie jak to sprawdzić
Im słabsze hamulce tym dalej zajedziesz
gość_
ok dzięki chłopaki za info, w takim razie pozostaje kupić HID,
[ Dodano: 2008-11-08, 21:11 ]
sprawdziłem jeszcze te kody ale nie znalazłem nic na temat lamp, albo mój angielski jest słabszy niż myślałem
X0A = National sales program Germany
P0A = code not found
C6U = Alloy wheels 7J x 17
Q0F = code not found
H6T = Tires 205/60 R15 V
J0L = Battery 340 A (70 Ah)
MTP = code not found
Q1A = Standard front seats
1BA = Standard suspension/shock absorption
1AJ = Anti-spin regulation (ABS/ASR/EDL) with electronic differential lock (EDL)
103 = code not found
2P0 = Without trunk sill protection
1N1 = Power steering
5RQ = Right exterior mirror: convex
TSL = code not found
T7T = 6-cylinder gasoline engine 2.4 L unit 078.7
0JL = Weight category front axle weight range 11
3S0 = Without roof rails/roof load rack
4UE = Air bag for driver and front seat passenger
0YD = Weight range 4 installation control only, no requirement forecast
007 = code not found
BUC = code not found
B0L = Component parts set, complying with vehicle type for Japan, various parts
GRE = code not found
1KD = Disc brakes, rear
1LB = Disc brakes, front
3FE = Electric slide/tilt sunroof with sun screen/sunblind
