C6 LIFT 3.0TDI CDYA ,wymiana silnika-silnik zgasł-pomocy
gawron931
Post autor: gawron931 » 16 lip 2017, 13:58
witam ,jestem nowy na forum a6klub .
kupiłem wczoraj audi a6 c6 lift 3.0tdi cdya 239km z Niemiec od gościa któremu silnik zgasł w czasie jazdy i ju z nie szło odpalić ,coś blokuje w silniku.
podaję błedy:
Address 01: Engine Labels: Redir Fail!
Control Module Part Number: 4F9 910 402 A HW: 4F0 907 401 E
Component and/or Version: 3.0TDI EDC17A000AG 0080
Software Coding: 0105002C190F0228
Work Shop Code: WSC 79707 146 03093
VCID: 24470A1BE72E243ED0B-8071
8 Faults Found:
000135 - Fuel Rail/System Pressure
P0087 - 014 - Too Low
Freeze Frame:
Fault Status: 01101110
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 187476 km
Time Indication: 0
Date: 2017.05.26
Time: 19:13:58
Freeze Frame:
RPM: 2016 /min
Speed: 175.8 km/h
Pressure: 773.9 bar
Temperature: 41.4°C
Pressure: 28.4 bar
(no units): 15.0
Bin. Bits: 00000000
P0087 - 012 - Too Low
Freeze Frame:
Fault Status: 01101100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 187476 km
Time Indication: 0
Date: 2017.05.26
Time: 19:13:58
Freeze Frame:
RPM: 2016 /min
Speed: 174.7 km/h
Pressure: 773.9 bar
Temperature: 41.4°C
Pressure: 14.2 bar
(no units): 15.0
Bin. Bits: 00000000
001814 - Transmission Input Speed Sensor (G182)
P0716 - 000 - Implausible Signal
Freeze Frame:
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 187476 km
Time Indication: 0
Date: 2017.05.26
Time: 19:13:59
Freeze Frame:
RPM: 2016 /min
Speed: 173.6 km/h
Load: 0.0 %
Voltage: 12.08 V
Bin. Bits: 00000000
(no units): 0.0
Bin. Bits: 00000001
053286 - Please Check Fault Codes in Transmission Control Module
U1026 - 001 - - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 2
Fault Frequency: 29
Reset counter: 255
Mileage: 187476 km
Time Indication: 0
Date: 2017.05.26
Time: 19:13:59
Freeze Frame:
RPM: 2016 /min
Speed: 173.6 km/h
Load: 0.0 %
Voltage: 12.01 V
Torque: 612.3 Nm
Bin. Bits: 00000001
U1026 - 000 -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 187476 km
Time Indication: 0
Date: 2017.05.26
Time: 19:13:59
Freeze Frame:
RPM: 2016 /min
Speed: 172.5 km/h
Load: 0.0 %
Voltage: 12.01 V
Bin. Bits: 00000000
(no units): 0.0
Bin. Bits: 00000001
000406 - Engine Oil Temp. Sensor (G8)
P0196 - 006 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00100110
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 187478 km
Time Indication: 0
Date: 2017.06.02
Time: 07:14:54
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Fuel Consump.: 0.00 l/h
Temperature: 15.3°C
Temperature: 15.3°C
Temperature: 16.2°C
Temperature: 15.3°C
001674 - ECM Power Relay Load Circuit: (J271)
P068A - 000 - De-Energized Performance Too Early - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Voltage: 0.00 V
Bin. Bits: 00000000
Bin. Bits: 00000000
Bin. Bits: 0
Temperature: -90.0°C
001153 - Coolant Fan Control Circuit 2
P0481 - 000 - Electrical Malfunction
Freeze Frame:
Fault Priority: 2
Fault Frequency: 23
Reset counter: 255
Mileage: 187478 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Temperature: 22.5°C
Mass Air / Rev.: 1192.6 mg/str
Duty Cycle: 0.0 %
Temperature: 17.7°C
liczę się z wymianą silnika lecz nie wiem czy tylko mam szukam takiego samego czy mogę zamontować nowszy blok CLA z a6 c7, proszę was o odpowiedź
jacob
Imię: Kuba
Rocznik: 2009
Silnik: 2.0 170KM
Post autor: jacob » 21 lip 2017, 20:25
Mi to wygląda na awarię pompy wysokiego ciśnienia CR, ale głowy obciąć sobie nie dam.
gawron931
Post autor: gawron931 » 02 wrz 2017, 16:07
Mechanik rozebral już silnik i muszę kupić 4 tłoki z korbowodami i lejki olejowe ,mechanik da głowice do plantowania i wal da do sprawdzenia czy prosty i regeneracji jak będzie prosty bo ma zadziory.
Blok cały ,mała dziura obok tulei do odmy
