Panowie takie coś trapi mojego mruczka.. ogólnie jak postoi na zewnątrz przy niskich temp, dłuugooo kręci, jak stoi w garażu zapala na dotyk.
VCDS tylko takie błędy wykazał.
Przekaźnik świec wymieniony.
VCDS Version: Release 12.12.0 (x64)
Address 01: Engine Labels: Redir Fail!
Control Module Part Number: 4F0 910 401 N HW: 4F0 907 401 B
Component and/or Version: 3.0L V6TDI A000AG 0010
Software Coding: 0011372
Work Shop Code: WSC 99999 999 999999
VCID: 275D1D179618CF26F59-8072
6 Faults Found:
005658 - Glowplug for Cylinder 1 (Q10)
P161A - 001 - Open Circuit
Freeze Frame:
Fault Status: 01110001
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 218765 km
Time Indication: 0
Date: 2015.07.23
Time: 10:56:55
Freeze Frame:
RPM: 798 /min
Torque: 85.8 Nm
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 13.76 V
Duty Cycle: 24.5 %
Temperature: 30.6°C
005659 - Glowplug for Cylinder 2 (Q11)
P161B - 001 - Open Circuit
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 218765 km
Time Indication: 0
Date: 2015.07.23
Time: 10:56:55
Freeze Frame:
RPM: 798 /min
Torque: 85.8 Nm
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 13.76 V
Duty Cycle: 24.5 %
Temperature: 30.6°C
005660 - Glowplug for Cylinder 3 (Q12)
P161C - 001 - Open Circuit
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 218765 km
Time Indication: 0
Date: 2015.07.23
Time: 10:56:55
Freeze Frame:
RPM: 798 /min
Torque: 85.8 Nm
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 13.76 V
Duty Cycle: 24.5 %
Temperature: 30.6°C
005661 - Glowplug for Cylinder 4 (Q13)
P161D - 001 - Open Circuit
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 218765 km
Time Indication: 0
Date: 2015.07.23
Time: 10:56:55
Freeze Frame:
RPM: 798 /min
Torque: 85.8 Nm
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 13.76 V
Duty Cycle: 24.5 %
Temperature: 30.6°C
005662 - Glowplug for Cylinder 5 (Q15)
P161E - 001 - Open Circuit
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 218765 km
Time Indication: 0
Date: 2015.07.23
Time: 10:56:55
Freeze Frame:
RPM: 798 /min
Torque: 85.8 Nm
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 13.76 V
Duty Cycle: 24.5 %
Temperature: 30.6°C
005663 - Glowplug for Cylinder 6 (Q15)
P161F - 001 - Open Circuit
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 218765 km
Time Indication: 0
Date: 2015.07.23
Time: 10:56:55
Freeze Frame:
RPM: 798 /min
Torque: 85.8 Nm
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 13.76 V
Duty Cycle: 24.5 %
Temperature: 30.6°C
Readiness: 0 0 0 0 0
A6 C6 3.0TDI BMK
maciek.bielsko
- Imię: Maciej
- Rocznik: 2015
- Silnik: 2.0TDI CAHA 170KM
Forum
- Imię: Forum
- Silnik: 2.8 FSI 210KM
Wszystkie świece żarowe, ale mało realne żeby padły wszystkie.
przekażnik w podszybiu str.pasażera lub bezpiecznik
poczytaj:
-bmk-30-224-km-blad-wszystkich-swiec-za ... t49506.htm
poczytaj:
maciek.bielsko
- Imię: Maciej
- Rocznik: 2015
właśnie to znalazłem,stwierdzam, że mam padnięte wszystkie 6 świec jak kolega "slg"
tylko niech ktoś mi powie jak wg softu sprawdzić co mam wgrane?? stalowe czy ceramiczne.. najlepiej krok po kroku wejście w menu i sprawdzenie wersji softu świec.
[ Dodano: 2015-12-29, 20:46 ]
kamil666, a gdzie ten bezpiecznik?? bo przekaźnik już wymieniłem
