[ BPP 2.7 179 KM] audi a6 2007 2.7tdi problem z turbo itp
carremaps
Post autor: carremaps » 16 cze 2013, 22:35
Mam problem z samochodem audi a6 2007 2.7tdi 180
Po scanie autocomem pojawily sie dwa bledy P1018 i P106B ( brakuje mocy i check engine )
Po zdjeciu gornej pokrywy widac ze caly czas otwiera sie i zamyka gruszka sterujaca turbina , i tak samo zawor obok kolektora tak samo otwiera sie i zamyka :/
Czy ktos spotkal sie juz kiedys z takim problemem ??
mbectb
Post autor: mbectb » 17 cze 2013, 09:29
Czyzby przepustnica ???? Sprawdz mialem takie auto kilka dni temu I sie okazalo ze przepustnica ta przed kolektorami byla uszkodzona objaw dokladnie taki sam jak opisujesz nastawnik turbiny I taki zaworek pomiedzy kolektorami kolo filtra ileju chodzily na okraglo. Pacjent taki sam jak opisujesz Audi A6 2007 2.7TDI BPP multitronic FWD. Pan Abdul Taksowkarz z Luton. Jesli to ten sam pacjent to do wymiany byla jeszcze Swieca zarowa na 2 cylindrze, naprawa polaczen w lampie tylnej, Klapa gaszaca oraz wyglada na to, ze kolektor bank 2 od strony pasazera patrzyc z przodu moze byc do poprawki chodz nie koniecznie.
Spojrz na post na angielskim forum
Cool Re: 005445 - Throttle Valve Controller - a different cause (and fix).
Quote Originally Posted by urgi View Post
did you have solved issue with bank 2?
It does seem that way. I have not managed to extinguish the MIL yet, but I'm now own to 2 genuine errors now. I really don't understand it, but it does appear to have gone since I had the EGR coolant bypass valve (see above) replaced. This has also had the side benefit of stopping the coolant leak and subsequent smell when the heating is used.
I doubt this is a common cause of the fault however. I can see absolutely no link between these two components but the combination of the diagnosis I did (removing the EGR electrical connection stopped the Bank 2 error) and the clearly worn component convinced me that replacing the valve was worth throwing £400 odd at it. Glad I did though as it's fixed 2 issues, saved me £1200+ on an unnecessary "repair" that wouldn't have made a difference and saved what looked like an impending breakdown.
Ideally I could do with changing the title of this thread as the Throttle Valve Controller is a completely separate and as yet unfixed error.
For reference, latest scan on my car is below:
Code:
Wednesday,16,January,2013,15:19:47:42852
VCDS Version: Release 11.11.5 (x64)
Data version: 20121222
Chassis Type: 4F0
Scan: 01 03 05 07 08 09 0E 0F 15 16 17 19 37 42 46 47 4F 52 53 56
61 62 72 76
VIN: WAUZZZ4F06N117103 Mileage: 299440km/186063miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
07-Control Head -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: OK 0000
0F-Digital Radio -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
Address 01: Engine Labels: Redir Fail!
Part No SW: 4F2 910 402 C HW: 4F0 907 401 B
Component: 2.7L V6TDI G000SG 0010
Revision: --H01--- Serial number:
Coding: 0011322
Shop #: WSC 02334 785 00200
VCID: 1F47A16BCE1AB8E0386
1 Fault Found:
P1545 - 002 - Malfunction
Freeze Frame:
Fault Status: 01100010
Fault Priority: 0
Fault Frequency: 2
Mileage: 299421 km
Time Indication: 0
Date: 2013.01.15
Time: 15:37:27
Freeze Frame:
RPM: 840 /min
Torque: 39.0 Nm
Speed: 0.0 km/h
Voltage: 13.91 V
Duty Cycle: 46.6 %
Bin. Bits: 000
Mass Air / Rev.: 481.8 mg/str
Readiness: 1 1 0 0 0
Address 03: ABS Brakes Labels: 4F0-910-517.lbl
Part No SW: 4F0 910 517 K HW: 4F0 614 517 K
Component: ESP 8.0 front H04 0090
Revision: 00000000 Serial number: 00000000000000
Coding: 0020871
Shop #: WSC 02325 785 00200
VCID: 2C5D46A78FAC5378AD4
No fault code found.
Address 05: Acc/Start Auth. Labels: 4F0-910-852.clb
Part No SW: 4F0 910 852 HW: 4F0 905 852 B
Component: FBSAUDIC6 ELV H31 0220
Revision: 31050601 Serial number: 10604000302669
Coding: 0000017
Shop #: WSC 00590 210 61861
VCID: E3CF6D9B22F25C00DCE
Part No: 4F0 910 131 D
Component: FBSAUDIC6 EZS H45 0070
Part No: 4F0 910 220 D
Component: FBSAUDIC6 IDG H01 0040
Address 07: Control Head Labels: 4F0-910-7xx-07-H.lbl
Part No SW: 4F1 910 732 D HW: 4E0 035 729
Component: Interfacebox H43 5570
Revision: 00000000 Serial number: 350KT057622196
Coding: 0000002
Shop #: WSC 02335 785 00200
VCID: 254BB383EC46623072A
Part No: 4F0 910 609 E
Component: Bedienteil MMIC6H03 0050
Address 08: Auto HVAC Labels: 4F0-910-043.lbl
Part No SW: 4F0 910 043 HW: 4F2 820 043 J
Component: KLIMABETAETIGUNGH12 0160
Revision: 00000027 Serial number: 00000000207203
Coding: 0001046
VCID: DBBF557B1A8264C094E
1 Fault Found:
00256 - A/C Pressure/Temperature Sensor (G395)
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 12
Mileage: 299421 km
Time Indication: 0
Date: 2013.01.15
Time: 15:50:20
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 E HW: 4F0 907 279 B
Component: ILM Fahrer H15 0190
Revision: 00000000 Serial number: 4F0907279
Coding: 0010101
VCID: 2B5F45BB8AA25440A4E
Subsystem 1 - Part No: 4F2 910 113 Labels: 1KX-955-119.CLB
Component: Wischer AudiC6 H04 0150
Coding: 00062736
Shop #: WSC 02335
Subsystem 2 - Part No: 4E0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH11 0050
Coding: 00141886
Shop #: WSC 02335
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 111 F HW: 4E0 035 111 A
Component: CD-Changer H44 0470
Revision: 00000000 Serial number: AUZ5ZBE8020478
Shop #: WSC 00000 000 00000
VCID: 1C3D9667DF0CA3F8DD4
Address 0F: Digital Radio Labels: None
Part No SW: 4E0 910 563 C HW: 4E0 035 563
Component: DAB-Tuner H41 0830
Revision: 00000001 Serial number: KE1229T8000349
Coding: 0000001
Shop #: WSC 02323 785 00200
VCID: 244DAE87E77C9B38654
Address 15: Airbags Labels: 4F0-910-655-8R.lbl
Part No SW: 4F0 910 655 E HW: 4F0 959 655 B
Component: 4E AIRBAG AUDI8RH29 0260
Revision: 07H29000 Serial number: 0037LD0B6UV-
Coding: 0013381
VCID: 2953BFB3805E4650562
Address 16: Steering wheel Labels: 4F0-910-549.lbl
Part No SW: 4F0 910 549 HW: 4F0 953 549 A
Component: Lenksäulenmodul H07 0230
Revision: 00H07000 Serial number: 90055053240161
Coding: 0102041
VCID: E6C9748FD1C029283B0
Part No: XXXXXXXXXXX
Component: Lenkradmodul H07 0090
Address 17: Instruments Labels: 4F0-910-xxx-17.lbl
Part No SW: 4F0 910 930 A HW: 4F0 920 980 M
Component: KOMBIINSTR. M73 H16 0630
Revision: 00200000 Serial number: 4PX31MJC5
Coding: 2308443
Shop #: WSC 06795 116 50998
VCID: 2143A793F86E8E100E2
Address 19: CAN Gateway Labels: 4F0-910-468.lbl
Part No SW: 4F0 910 468 A HW: 4F0 907 468 D
Component: Gateway H11 0070
Revision: 11 Serial number: 1300805B210123
Coding: ECEE53C41B2904
VCID: 2757B98B964A7020406
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 P HW: 4E0 919 887 D
Component: MNS ECE H47 1060
Revision: 00000000 Serial number: 364K-057509824
VCID: 3B7F75FB7AC2C4C034E
Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
Part No SW: 4F0 910 793 E HW: 4F0 959 793 E
Component: TSG FA H12 0080
Revision: 00-00000
Coding: 0002682
Shop #: WSC 02327 785 00200
Address 46: Central Conv. Labels: 4F0-910-289.lbl
Part No SW: 4F0 910 289 G HW: 4F0 907 289 G
Component: Komfortgeraet H22 0170
Revision: 01700022 Serial number: 01008809340000
Coding: 0008443
VCID: 2E594CAFB9B02168830
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Part No: 4F0 910 177
Component: Innenraumueberw.H01 0020
Address 47: Sound System Labels: 4F0-910-223-AS.lbl
Part No SW: 4F0 910 223 G HW: 4F0 035 223
Component: Amp.-ASK H10 0350
Revision: 32S00001 Serial number: 02711050183176
Coding: 0000003
VCID: 2241A89FFD689508178
Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
Part No SW: 4F0 910 280 HW: 4F0 907 280 A
Component: ILM Beifahrer H10 0080
Revision: Serial number: 00000000161557
Coding: 0001103
VCID: DEB95C6F099071E8F30
Tam podobna kombinacja bledow I blad kolektora 2 ustal po wymianie
Czipsy, Diagnostyka, Flashowanie UK
Rozrząd Audi A6 C6 2.7 TDI BPP.
carremaps
naprawione
Post autor: carremaps » 18 cze 2013, 19:10
naprawione :) przepustnica
mbectb
Post autor: mbectb » 18 cze 2013, 19:23
A blad kolektora znikl po naprawie przepustnicy ?
