[ A6 C6 2.0 Tdi] [A6 C6 2.0 TDI BLB] niechce odpalic zczytan
Drakula7410
Post autor: Drakula7410 » 15 wrz 2011, 06:53
Witam dzisiaj w czasie jazdy zgaslo mi altko i juz nie mozna odpalic podpielem vcds i oto logi bardzo prosze o pomoc-------------------------------------------------------------------------------
Address 03: ABS Brakes Labels: 4F0-910-517.lbl
Part No SW: 4F0 910 517 D HW: 4F0 614 517
Component: ESP8 front H03 0010
Revision: 00000000 Serial number: 00000000000000
Coding: 0004471
Shop #: WSC 02325 785 00200
VCID: 254AF3CAD3BB1034
1 Fault Found
00532 - Supply Voltage B+
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 115
Mileage: 164455 km
Time Indication: 0
Date: 2011.09.15
Time: 02:36:36
Freeze Frame:
Hex Value: 0x3F80
Hex Value: 0x0102
Hex Value: 0x0012
Hex Value: 0x007A
Hex Value: 0x00FF
Address 07: Control Head Labels: 4F0-910-7xx-07-H.lbl
Part No SW: 4F0 910 729 Q HW: 4E0 035 729
Component: Interfacebox H43 0500
Revision: 00000000 Serial number: 350JN047541660
Coding: 0000002
Shop #: WSC 02335 785 00200
VCID: 37762982791792A4
Part No: 4F0 910 609
Component: Bedienteil MMIC6H03 0870
1 Fault Found
01317 - Control Module in Instrument Cluster (J285)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 5
Fault Frequency: 2
Reset counter: 39
Mileage: 164040 km
Time Indication: 0
Date: 2011.09.03
Time: 01:30:00
Freeze Frame:
Bin. Bits: 10
Address 53: Parking Brake Labels: 4F0-910-801.lbl
Part No SW: 4F0 910 801 HW: 4F0 907 801
Component: EPB C63C0030 H03 0030
Revision: C63C0030
Coding: 0000111
Shop #: WSC 00562 210 06478
VCID: DDBA1B2A3B6B18F4
1 Fault Found
01316 - ABS Control Module
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 3
Fault Frequency: 2
Reset counter: 115
Mileage: 164448 km
Time Indication: 0
Date: 2011.09.15
Time: 02:36:42
Freeze Frame:
Voltage: 8.90 V
Count: 236
jasper
Imię: Jacek
Moje auto: Allroad C5
Silnik: 2.5TDI AKN 150KM
Post autor: jasper » 16 wrz 2011, 20:56
sprawdź okablowanie, złączki, cany po bokach wina leży w napięciu, sprawdź też akumulator i sterownik aku, oraz alternator jego podłączenia i kostki.
wiesiek1902
Post autor: wiesiek1902 » 18 lis 2011, 23:20
raczej stawialbym na okablowanie alternatora.
mam podobny objaw kompyter pokazuje mi rozladowany akumulator ,10%, jadnak mimo to auto pali bez zarzutow,wydaje mi sie ze strzalil sterownik aku.
wiec u kolegi jesli podczas jazdy autko zgaslo to wskazuje raczej na brak ładowania i rozładowanie aku wie proponuje sprawdzis styki alternatora.
