Witam ,możecie mi pomóc w rozszyfrowaniu diagnostyki ,zapala mi się pomarańczowa kontrolka .Poniżej wykaz .
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
07-Control Head -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine Labels: Redir Fail!
Part No SW: 4F0 910 401 J HW: 4F0 907 401 A
Component: 3.0L V6TDI G000AG 0030
Revision: --H01--- Serial number:
Coding: 0011772
Shop #: WSC 02334 785 00200
VCID: 234EF308DD8FEE04
1 Fault Found:
005445 - Throttle Valve Controller: Malfunction
P1545 -- 002 -- Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 0
Fault Frequency: 158
Mileage: 185661 km
Time Indication: 0
Date: 2011.06.01
Time: 13:55:24
Freeze Frame:
RPM: 756 /min
Torque: 74.1 Nm
Speed: 4.5 km/h
Voltage: 13.60 V
Duty Cycle: 22.1 %
Bin. Bits: 000
Mass Air / Rev.: 299.6 mg/str
Readiness: 0 1 0 0 0
Address 02: Auto Trans Labels: 09L-927-760.lbl
Part No SW: 4F0 910 156 H HW: 09L 927 156
Component: AG6 09L 3.0lTDI RdW 0100
Revision: 00000001 Serial number: ÿÿÿÿÿÿÿ
Coding: 0000001
Shop #: WSC 21351 136 52174
VCID: 2854E424A4A90D5C
1 Fault Found:
17087 - Brake Switch (F): Electrical Malfunction
P0703 -- 000 -- - - Intermittent
Freeze Frame:
Fault Status: 00110000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 40
Mileage: 180067 km
Time Indication: 0
Date: 2011.01.07
Time: 16:03:29
Freeze Frame:
RPM: 768 /min
RPM: 0 /min
RPM: 0 /min
(no units): 1.0
(no units): 30.0
Temperature: 62.0°C
T.B. Angle: 0.0°
Address 03: ABS Brakes Labels: 4F0-910-517.lbl
Part No SW: 4F0 910 517 E HW: 4F0 614 517 A
Component: ESP8 quattro H03 0010
Revision: 00000000 Serial number: 00000000000000
Coding: 0020872
Shop #: WSC 02325 785 00200
VCID: 2648EA1CAEBD1B2C
No fault code found.
[ A6 C6 3.0 Tdi] [A6 C6] Rozszyfrowanie diagnostyki 3.0 Quat
MaTyS
- Imię: MaTyS
- Rocznik: 2012
- Silnik: 3.0 TDI 233KM
Zacznij od skasowania błędów, jeżeli powrócą to
pierwszy:
https://a6klub.pl/a6-c6-27tdi-problem-z-przepustnica-vt15282,240.htm
tutaj drugi:
https://a6klub.pl/a6-c6-po-zwolnieniu-recznego-nadal-swieci-sie-kontrolka-vt18691.htm?highlight=17087
pierwszy:
tutaj drugi:
