Kody błędów- pomoc
Diagnostyka VAG
Waka23666
Imię: Art
Rocznik: 2013
Moje auto: Allroad C7
Silnik: 3.0 TDI 204KM
Kody błędów- pomoc
Post autor: Waka23666 » 06 cze 2019, 17:21
Cześć.
Przeskanowałem mojego allroada vcds i wyskoczyły takie błędy
Czy ktoś może mi pomóc?
: 4G0 820 043 AK HW: 4G0 820 043 AK
Component: KLIMA 2 ZONEN H14 0096
Serial number: 23041400112066
Coding: 3622000829
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_AirCondiBasisUDS 004002
ROD: EV_AirCondiBasisUDS_004.rod
VCID: 68DE308993C63E0A75-803C
4 Faults Found:
0245 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
[New feature! Extended UDS fault detail is only supported by current gen. interfaces]
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 4
Reset counter: 99
Mileage: 166014 km
Date: 2019.05.29
Time: 13:18:08
Voltage terminal 30: 14.68 V
Outside air temperature: 18.0 °C
Interior temperature: 36.21 °C
0392 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Reset counter: 99
Mileage: 166014 km
Date: 2019.05.29
Time: 13:18:08
0400 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Reset counter: 99
Mileage: 166014 km
Date: 2019.05.29
Time: 13:18:08
0401 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Reset counter: 99
Mileage: 166014 km
Date: 2019.05.29
Time: 13:18:08
Address 09: Cent. Elect. (J519) Labels:. 4H0-907-063-V1.clb
Part No SW: 4H0 907 063 CG HW: 4H0 907 063
Component: BCM1 2.0 H12 0130
Revision: 11012002 Serial number: 00000001536935
Coding: 690000108074A7E00905008320005F5FCF9D67082F080201000004406000
Shop #: WSC 23883 002 1048576
VCID: 6FEC5B95BE28E93234-803A
Subsystem 1 - Part No SW: 4G2 955 119 HW: 4G8 955 119 A Labels: 1KX-955-119.CLB
Component: WWS57X 140326 H37 0080
Serial number: 140329012335
Coding: 0045F7
Subsystem 2 - Part No SW: 8U0 955 559 B HW: 8U0 955 559 B Labels: 8U0-955-559.CLB
Component: G397_RLFS H06 0002
Serial number: 22518383
Coding: 02006D
Subsystem 3 - Part No SW: 4G0 941 531 M HW: 4G0 941 531 M
Component: E1 - LDS H07 0044
Serial number: 10 12 2012 00000309
Subsystem 4 - Part No SW: 4G0 907 658 A HW: 4G0 907 658 A
Component: Humidity_Sens H03 0002
Serial number: EA088F17000000000001
1 Fault Found:
01229 - A/C Humidity Sensor (G260)
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 3
Fault Frequency: 1
Reset counter: 93
Mileage: 166014 km
Time Indication: 0
Date: 2019.05.29
Time: 13:18:00
Address 3B: Sensor Elect. (J849) Labels: 4G0-907-637.clb
Part No SW: 4G0 907 637 K HW: 4G0 907 637 F
Component: SARA 6D H03 0056
Revision: -------- Serial number: EJ1BPA8206Z7FO
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_SARA2 005012
ROD: EV_SARA2.rod
VCID: 3662AEF189F298FA37-8062
1 Fault Found:
10485793 - Operation of Inclination Display
C113F F0 [008] - System Not Available
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 137
Mileage: 166147 km
Date: 2019.06.04
Time: 20:49:46
DCU_Internal_DTC: A0 00 21
Ignition Cycle Count: 24230
DCU Temperature: 22 °C
Voltage terminal 30: 13.8 V
Voltage VBG 22: 2.5 V
Debug Data: 01 00 B8 00 00 00 20 0F
Address 46: Central Conv. (J393) Labels:. 4H0-907-064-46.clb
Part No SW: 4H0 907 064 EH HW: 4H0 907 064 EH
Component: BCM2 2.0 H36 0521
Revision: 00002001 Serial number: 0332493552
Coding: 013B0E22A0B930158320098420010F470000000000000000000000000000
VCID: 73E457E5D200CDD2D0-8026
Subsystem 1 - Part No: 4G0 951 177
Component: DWA-Sensor H01 0010
Subsystem 2 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Subsystem 3 - Part No SW: 4G9 959 591 HW: 8V3 959 591
Component: J245 PS20.008 H02 0007
Serial number: WOO2803422
Coding: 901E00
Subsystem 4 - Part No SW: 4G0 947 135 K HW: 4G0 947 135
Component: Dachelektroni H10 0100
Serial number: 0000000AP00006657434
Coding: 010000
Subsystem 5 - Part No SW: 4G9 959 591 HW: 8V3 959 591
Component: J394 PS20.008 H02 0007
Serial number: WOO2803423$
Coding: 801E00
1 Fault Found:
02616 - Fuel Tank Cap; Unlock
009 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00101001
Fault Priority: 2
Fault Frequency: 10
Reset counter: 137
Mileage: 166027 km
Time Indication: 0
Date: 2019.05.30
Time: 03:20:42
Address 5F: Information Electr. (J794) Labels:. 4E0-035-6xx-5F.clb
Part No SW: 4G0 035 670 J HW: 4G0 035 670 J
Component: H-BNT-EU H53 0798
Revision: -------- Serial number: 190D%0E7583546
Coding: 080101050003F1ED0580AB3E00000003000001000200000000
VCID: 2A5A8A81454ACC1AA3-807E
Subsystem 1 - Part No: 8R0 060 884 BK
Component: EUR 2014 1703
Subsystem 2 - Part No SW: 4G0 919 605 C HW: 4G0 919 605 C
Component: DU8 C7 SV H43 0021
Serial number: AUZ8ZDED004A65B
Subsystem 3 - Part No SW: 4G2 919 612 Q HW: 4G2 919 612 Q
Component: E380 BDT C7 H11 0204
Serial number: 90349NDB001BN
Subsystem 4 - Part No: 8R0 060 961 F
Component: CD-Database 5571
1 Fault Found:
03787 - Rotation Mechanism for Display Module Front
003 - Mechanical Failure - Intermittent
Freeze Frame:
Fault Status: 00100011
Fault Priority: 6
Fault Frequency: 7
Reset counter: 134
Mileage: 166090 km
Time Indication: 0
Date: 2019.06.01
Time: 15:34:17
Freeze Frame:
Voltage: 12.40 V
