wymiana drzwi, błąd po wymianie
Diagnostyka VAG
ink100
Post autor: ink100 » 23 maja 2018, 14:45
kupiłem samochód w którym wymieniane były drzwi(zamek,szyba,glosniki itp wszystko zostało). w VCDS wywala mi za to blędy, a wszystko z drzwiami jest ok. glosniki dzialaja, swiatla, zamykaja sie drzwi, wszystko sprawne.. pomozecie? :) oto bledy:
Kod: Zaznacz cały
Address 19: CAN Gateway (J533)       Labels: None
   Part No SW: 4G0 907 468 E    HW: 4G0 907 468 A
   Component: J533--Gateway H08 0213
   Revision: --------    Serial number: 00000000193249
   Coding: 00CD077D00
   Shop #: WSC 02311 785 00200
   ASAM Dataset: EV_GatewUDS 001025
   ROD: EV_GatewUDS_AU57.rod
   VCID: 326BFC4365DABA8E527-8067
   Battery Monitoring Control Module:
   Subsystem 1 - Part No SW: 8X0 915 181     HW: 8X0 915 181
   Component: J367-BDM  H07 0140
   Serial number: 00000000005650853009
   Voltage stabilizer:
1 Fault Found:
5075 - Door Control Module - Rear Right
          U0202 00 [008] - No Communications
          Intermittent - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 90
                    Mileage: 145132 km
                    Date: 2018.03.30
                    Time: 10:31:04
Address 28: HVAC, Rear (E265)       Labels: 4G0-919-158.clb
   Part No SW: 4G0 919 158 D    HW: 4G0 919 158 D
   Component: KLIMA FOND    H07 0056
   Serial number: 09071100040844
   Coding: 01
   ASAM Dataset: EV_ClimaContrUnitRearUDS 002012
   ROD: EV_ClimaContrUnitRearUDS.rod
   VCID: 306FF64B6BD6889E243-8065
2 Faults Found:
0033 - Motor for Rear Right Upper Body Vent
          B10D4 22 [008] - Signal Amplitude Too High
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 56
                    Reset counter: 121
                    Mileage: 142436 km
                    Date: 2018.01.19
                    Time: 14:40:36
0075 - Button or Switch in Operating Unit
          B10C7 07 [008] - Mechanical Failure
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 96
                    Mileage: 145926 km
                    Date: 2018.04.24
                    Time: 13:44:14
Address 46: Central Conv. (J393)       Labels: 4H0-907-064-46.clb
   Part No SW: 4H0 907 064 DP    HW: 4H0 907 064 BP
   Component: BCM2 2.0      H31 0510
   Revision: 00002001    Serial number: 0153515102
   Coding: 0100062000B93504832008040A0100000000000000000000000000000000
   Shop #: WSC 02391 785 00200
   VCID: 7AFB1463F52A82CEDA7-802F
   Subsystem 1 - Part No SW: 7P5 959 591     HW: 4H0 959 591
   Component: J245 PS40.033  H07 0006
   Coding: 001F00
1 Fault Found:
01334 - Door Control Module; Rear Right (J389)
            004 - No Signal/Communication - Intermittent
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 90
                    Mileage: 145132 km
                    Time Indication: 0
                    Date: 2018.03.30
                    Time: 10:31:37
Address 47: Sound System (J525)       Labels: None
   Part No SW: 4G0 035 223 C    HW: 4G0 035 223 A
   Component: BOSE-G3-C7    H07 0160
   Revision: CJ007000    Serial number: 00000000012208
   Coding: 030000
   Shop #: WSC 33322 001 1048576
   VCID: 1D313FFF044415F69F5-8048
2 Faults Found:
00877 - Treble Speaker Rear Right (R16)
            011 - Open Circuit - Intermittent
             Freeze Frame:
                    Fault Status: 00111011
                    Fault Priority: 4
                    Fault Frequency: 12
                    Reset counter: 90
                    Time Indication: 0
02559 - Rear Right Mid-Range/Woofer Loudspeaker (R160)
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 12
                    Reset counter: 90
                    Time Indication: 0
Address 52: Door Elect, Pass. (J387)       Labels: None
   Part No SW: 4G8 959 792 E    HW: 4G8 959 792 A
   Component: TSG BF        H05 0212
   Revision: --------    Serial number: --------------
   Coding: 011F16204000628002080002
   VCID: 4189A38FD87C1116DBD-8014
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 5
                    Reset counter: 90
                    Mileage: 145132 km
                    Time Indication: 0
                    Date: 2018.03.30
                    Time: 10:31:41
Address 6D: Trunk Elect. (----)       Labels: None
   Part No SW: 4G5 959 107 A    HW: 4G5 959 107
   Component: HDSG-Modul    H01 0038
   Revision: 13001001    Serial number: 178100433
   Coding: 111104C000
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_HDSGAu571 001001
   ROD: EV_HDSGAu571_AU57.rod
1 Fault Found:
0017 - Hall Sensors in Motor 1 for Rear Lid
          B1211 02 [008] - Signal Failure
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 87
                    Mileage: 144837 km
                    Date: 2018.03.08
                    Time: 11:58:39
Address 72: Door, Rear Right (J389)       Labels: None
   Part No SW: 4G8 959 795 E    HW: 4G8 959 795 A
   Component: TSG HR        H04 0212
   Coding: 010F14204000628002080002
   VCID: 4487AA9BC76E043EF0B-8011
1 Fault Found:
02123 - Door Warning Light / Entry Light
            012 - Electrical Fault in Circuit - Intermittent
             Freeze Frame:
                    Fault Status: 00101100
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 90
                    Mileage: 145132 km
                    Time Indication: 0
                    Date: 2018.03.30
                    Time: 10:19:58
Ostatnio zmieniony 23 maja 2018, 19:18 przez ink100, łącznie zmieniany 1 raz.
Post autor: mat1324 » 23 maja 2018, 15:15
Po skasowaniu, które błędy pojawiają się ponownie?
ink100
Post autor: ink100 » 23 maja 2018, 16:16
Dziwnym trafem wszystkie...
damos
Imię: Damos
Silnik: 3.0 CDYA 239KM
Post autor: damos » 23 maja 2018, 16:41
To nie dziwny traf. To brak sprawnego połączenia ze sprawnymi modułami :(
Z tym kasowaniem błędów też coś nie halo, bo przebiegi są różne. Jaki przebieg masz teraz?
ink100
Post autor: ink100 » 23 maja 2018, 16:47
kurde, nie skasowalem bledow, nacisnalem nie ta komende... zaraz ogram wszystko ;)
edit a tak poza tym jak mam wywolac te bledy? uruchamiajac auto tylko?
Post autor: mat1324 » 23 maja 2018, 17:09
Skasuj błędy, a najlepiej zrobić to wchodząc do każdego sterownika z osobna, ponieważ automatyczne kasowanie błędów z poziomu auto-scanu wszystkich nie rusza. Potem zrób małą jazdę testową, otwórz/zamknij drzwi, opuść/podnieś szyby itd.
ink100
Post autor: ink100 » 23 maja 2018, 18:58
jestem po. wykasowane bledy nie wrocily. byc moze musze dluzej pojezdzic. otwieralem zamykalem drzwi, szyby, ciaglem za klamke, probowalem wszystkiego.
a tak przy okazji posle blędy ktore mialem wczesniej, kompletnie nic z tego nie rozumiem. blad z modulu 55 wyswietla mi sie obok licznika a modul 3 zaczal niedawno szwankowac.
Kod: Zaznacz cały
Chassis Type: 4G (4G0)
Scan: 01 02 03 05 08 09 0E 10 15 16 17 18 19 28 3B 42 44 46 47 52
          53 55 56 5F 62 6C 6D 72 8F 90
VIN: WAUZZZ4G9CN025962
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
18-Aux. Heat -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
28-HVAC, Rear -- Status: OK 0000
3B-Sensor Elect. -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Xenon Range -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
6D-Trunk Elect. -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
8F-Pretens. Frt Left -- Status: OK 0000
90-Pretens. Frt Right -- Status: OK 0000
Address 01: Engine (J623-CDUC)       Labels: Redir Fail!
   Part No SW: 4G0 907 401 F    HW: 4G0 907 401
   Component: 3.0TDI EDC17  H37 0004
   Revision: 53H37---
   Coding: 0A25401A042601020000
   ASAM Dataset: EV_ECM30TDI0114G0907401F 001004
   ROD: EV_ECM30TDI0114G0907401F.rod
   VCID: 264310135912D62ECEF-8073
No fault code found.
Readiness: 0 0 0 0 0
Address 02: Auto Trans (J217)       Labels: 0B5-927-156.clb
   Part No SW: 4G1 927 156 B    HW: 0B5 927 156 F
   Component: 0B5 30 TDIRdW H10 0001
   Revision: --H10---    Serial number: 0000000013
   Coding: 000001
   ASAM Dataset: EV_TCMDL501 A02087
   ROD: EV_TCMDL501.rod
   VCID: 2C57E23B47FEEC7E18B-8079
Address 03: ABS Brakes (J104)       Labels: 4G0-907-379.clb
   Part No SW: 4G0 907 379 F    HW: 4G0 907 379 F
   Component: ESP PREMIUM   H09 0250
   Coding: 27A68701E465E180DB00
   ASAM Dataset: EV_ESPPremiAU57X 004017
   ROD: EV_ESPPremiAU57X.rod
   VCID: 3467FA5B9FCEB4BE40B-8061
1 Fault Found:
0785 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 83
                    Mileage: 147765 km
                    Date: 2018.05.23
                    Time: 17:25:40
Address 05: Acc/Start Auth. (J393)       Labels: 8K0-907-064-05.clb
   Revision: 00002001
   Coding: 01A83006000000000000
   Shop #: WSC 29521 002 1048576
Address 08: Auto HVAC (J255)       Labels: None
   Part No SW: 4G0 820 043 K    HW: 4G0 820 043 K
   Component: KLIMA 4 ZONEN H11 0056
   Serial number: 10071100040614
   Coding: 361100B828
   ASAM Dataset: EV_AirCondiComfoUDS 002029
   ROD: EV_AirCondiComfoUDS.rod
   VCID: 275D1D175E18CF26F59-8072
Address 09: Cent. Elect. (J519)       Labels: 4H0-907-063.clb
   Part No SW: 4H0 907 063 BF    HW: 4H0 907 063 F
   Component: BCM1 2.0      H12 0100
   Revision: 20012002    Serial number: 00000001125800
   Coding: 2600201040349FE08181008300001D0CCF9CC30826090101000008602101
   VCID: 6DD12F3FB46425764F5-8038
   Subsystem 1 - Part No SW: 4G1 955 119     HW: 4G8 955 119
   Component: WWS57X 110621  H35 0051
   Coding: 0045F7
   Subsystem 2 - Part No SW: 8K0 955 559     HW: 8K0 955 559   Labels: 8K0-955-559.CLB
   Component: RLS  H04 0003
   Coding: 02512B
   Subsystem 3 - Part No SW: 4G0 941 531 E    HW: 4G0 941 531 E
   Component: E1 - LDS  H07 0044
   Subsystem 4 - Part No SW: 4H0 907 658     HW: 4H0 907 658
   Component: AQ_Hum_Sensor  H02 0002
Address 0E: Media Player 1 (R41)       Labels: Redir Fail!
   Part No SW: 8X0 035 110 C    HW: 8X0 035 110
   Component: CDC-MP3-Pana  H41 0490
   Revision: 00000007
   VCID: 2D51EF3F74E4E5760F5-8078
Address 10: Park/Steer Assist (J446)       Labels: 4H0-919-475-7X2.clb
   Part No SW: 4H0 919 475 L    HW: 4H0 919 475 C
   Component: PARKHILFE ACC H07 0043
   Revision: 11001001    Serial number: 55901118600085
   Coding: 280305
   Shop #: WSC 20834 123 98811
   ASAM Dataset: EV_EPHVA18AU57X0000 002005
   ROD: EV_EPHVA18AU57X0000.rod
   VCID: 3B75D167B2907BC6811-806E
Address 15: Airbags (J234)       Labels: None
   Part No SW: 4H0 959 655 C    HW: 4H0 959 655 C
   Component: Airbag10.43   H40 0040
   Revision: --------    Serial number: 003JG0036UZQ
   Coding: 30323436313330303435554A304C34473053
   ASAM Dataset: EV_AirbaAU10BPAAU64X 001014
   ROD: EV_AirbaAU10BPAAU64X_AU57.rod
   VCID: 3663C05389B2A6AE7EF-8063
   Crash sensor for side airbag; driver side:
   Serial number: 3575HRB405L0IDFKEHG3
   Crash sensor for side airbag; passenger side:
   Serial number: 3585HRB405V0INGS7PP0
   Crash sensor for side airbag; rear driver side:
   Serial number: 3515JRB40570JL5E78D2
   Crash sensor for side airbag; rear passenger side:
   Serial number: 3525JRB404R0K4DOA8O
   Crash sensor for front airbag; driver side:
   Serial number: 3554VRB405T0JE3GK90X
   Crash sensor for front airbag; passenger side:
   Serial number: 3564VRB405T0JE3GBGG5
Address 16: Steering wheel (J527)       Labels: None
   Part No SW: 4G0 953 568 A    HW: 4G0 953 568 A
   Component: Lenks.Modul   H05 0201
   Revision: 00000000    Serial number: 20110710000001
   Coding: 000014
   VCID: 306FF64B63D6889E243-8065
   Subsystem 1 - Part No SW: 4G0 951 528 C    HW: 4G0 951 528 C
   Component: E221 - MFL  H07 0009
Address 17: Instruments (J285)       Labels: 4H0-920-xxx-17.clb
   Part No SW: 4G8 920 931 E    HW: 4G8 920 931 E
   Component: TDieRdw       H71 0375
   Revision: 26181114    Serial number: 658130711592033
   Coding: 03A609000B010008000000
   ASAM Dataset: EV_RBD4K 004040
   ROD: EV_RBD4K.rod
Address 18: Aux. Heat (J364)       Labels: Redir Fail!
   Part No SW: 4H0 265 105 E    HW: 4H0 265 105 E
   Component: Standheizung  H24 0250
   Revision: 66006006    Serial number: 20110620114105
   Coding: 5D3B00
   VCID: 24470A1B272E243ED0B-8071
   Coding: 00CD077D00
   Voltage stabilizer:
   Coding: 01
Address 3B: Sensor Elect. (J849)       Labels: 4G0-907-637.clb
   Part No SW: 4G0 907 637 B    HW: 4G0 907 637 B
   Component: SARA 6D       H02 0004
   Revision: --------    Serial number: EJ1BPA4201BA4Q0
   ASAM Dataset: EV_SARA 006014
   ROD: EV_SARA.rod
   VCID: 2D51EF3F7CE4E5760F5-8078
Address 42: Door Elect, Driver (J386)       Labels: None
   Part No SW: 4G8 959 793 E    HW: 4G8 959 793 A
   Component: TSG FA        H05 0212
   VCID: 428BAC83DD7A0A0EC27-8017
Address 44: Steering Assist (J500)       Labels: None
   Part No SW: 4G0 909 144 L    HW: 4G0 909 144 G
   Component: RCEPS         H38 0010
   Revision: 00001000    Serial number: 0012760588
   Coding: 101000010000
   Shop #: WSC 37477 000 1048576
   ASAM Dataset: EV_RCEPS 009008
   ROD: EV_RCEPS.rod
   Coding: 001F00
   Coding: 030000
Address 53: Parking Brake (----)       Labels: 4H0-907-801.clb
   Part No SW: 4H0 907 801 E    HW: 4H0 907 801 A
   Component: EPB-4         H03 0012
   Revision: --------    Serial number: 00000000101291
   ASAM Dataset: EV_ParkiBrake 001022
   ROD: EV_ParkiBrake_AU48.rod
   VCID: 2A5BE4234D0AF24EEA7-807F
Address 55: Xenon Range (J431)       Labels: None
   Part No SW: 4H0 907 357 A    HW: 4H0 907 357 A
   Component: ....LWR12.... H02 0013
   Serial number: 110707-0004-172
   Coding: 1121A6101002A300
   ASAM Dataset: EV_HeadlRegulBasic 005001
   ROD: EV_HeadlRegulBasic.rod
1 Fault Found:
126986 - Front Left Ride-Height Sensor
          C1034 15 [137] - Open or Short to Plus
          MIL ON - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 83
                    Mileage: 147765 km
                    Date: 2018.05.23
                    Time: 17:22:47
Address 56: Radio (R)       Labels: Redir Fail!
   Part No SW: 4G1 035 053 E    HW: 4G1 035 053
   Component: Radio U Basic H41 0093
   Revision: AB001007    Serial number: 049GW0BB008312
   Coding: 010003010000000001
   VCID: 2149030F383C3116BBD-8074
Address 5F: Information Electr. (J794)       Labels: 4E0-035-6xx-5F.clb
   Part No SW: 4G0 035 670 G    HW: 4G0 035 670
   Component: H-BNT-EU      H47 0484
   Revision: --------    Serial number: 428I20B7523649
   Coding: 050100000003E3EF05108B3E00000003000001000000000000
   VCID: 275D1D175618CF26F59-8072
   Subsystem 1 - Part No: 8R0 060 884 N
   Component: EUR 2011  1205
   Subsystem 2 - Part No SW: 4G0 919 605 A    HW: 4G0 919 605 A
   Component: DU8 C7 SV  H42 0021
   Subsystem 3 - Part No SW: 4G1 919 610 C    HW: 4G1 919 610 A
   Component: E380 BDT C7  H08 0204
   Subsystem 4 - Part No: 8R0 060 961 B
   Component: CD-Database  3371
Address 62: Door, Rear Left (J388)       Labels: None
   Component: TSG HL        H04 0212
Address 6C: Back-up Cam.        Labels: 4H0-907-441.clb
   Part No SW: 4G0 907 441 B    HW: 4H0 907 441
   Component: SG Rueckfahrkamera  0061
   Revision: --H04---    Serial number: 525 PA8J1XG3S5
   Coding: 1080004
   VCID: 264310139112D62ECEF-8073
   Coding: 111104C000
Address 8F: Pretens. Frt Left (J854)       Labels: 4H0-980-94x-RGS.clb
   Part No SW: 4H0 980 945     HW: 4H0 980 945
   Component: RGS-VL        H05 0070
   Coding: 00060000031F030000030801424CDA010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
   VCID: EFEDB53736685766FD9-80BA
Address 90: Pretens. Frt Right
Cannot be reached
End   ---------------------------------------------------------------------
damos
Imię: Damos
Post autor: damos » 23 maja 2018, 20:51
ink100 pisze:kurde, nie skasowalem bledow, nacisnalem nie ta komende... zaraz ogram wszystko
A nie mówiłem?
Powiedz jeszcze, jaki masz przebieg, bo jeśli pokazujesz nam błędy, które wystąpiły 30 tys. km temu - to szkoda czasu :)
Błędy mogę się pojawić przy spadku napięcia, więc jeśli masz kłopoty z akumulatorem, to też może powodować kłopoty.
Post autor: mat1324 » 23 maja 2018, 21:47
Jeśli wymienisz przedni lewy czujnik poziomowania, to błąd w sterowniku [55] zniknie i na 90% ten z ABS też :).
ink100
Post autor: ink100 » 23 maja 2018, 22:45
Dla mojego auta czesc ma numer 8R0941309C?
edit; badz też 4F0 941 285 F ?
Post autor: mat1324 » 23 maja 2018, 23:43
Żaden z tych numerów :).
Czujnik lewy przód: 4H0 941 285 H. Przy pneumatycznym zawieszeniu zamiast końcowej literki H jest G.
ink100
Post autor: ink100 » 13 cze 2018, 17:29
czujnik wymienilem, błędy się zgubiły. dziekuje za pomoc :)
