VCDS Błąd 1048578, 01042 i 03276
Diagnostyka VAG
Adusadi
Imię: Adrian
Rocznik: 2013
Post autor: Adusadi » 22 paź 2020, 13:39
Witam wszystkich :)
Ostatnio upgradowalem system RMC do k16158, bluetooth do 3.70 i wczesniej dolozylem osiwetlenie ambiente w drzwiach.
Po tych operacjach wyskoczyly mi takie bledy......
Jest moze jakis magik, ktory pomoze mi z nimi ????
Oto moj log:
Kod: Zaznacz cały
Saturday,31,October,2020,14:29:30:00009
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 20.4.1.0 (x64)
Data version: 20200331 DS317.0
www.Ross-Tech.com
VIN: WAUZZZ4GXEN189238   License Plate: LK67JVA
Mileage: 72302km-44926mi   Repair Order:
Chassis Type: 4G-AU57 (4G0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 3B 42 44 46 52 53 55 5F 62
          6D 72 AC
VIN: WAUZZZ4GXEN189238   Mileage: 72302km-44926miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
3B-Sensor Elect. -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: Malfunction 0010
6D-Trunk Elect. -- Status: OK 0000
72-Door, Rear Right -- Status: Malfunction 0010
AC-Reductant Control -- Status: OK 0000
Address 01: Engine (J623-CNHA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 021 BD    HW: 04L 907 309
   Component: R4 2,0L EDC   H23 8244
   Revision: 85H23---
   Coding: 12254012242401080000
   Shop #: WSC 28105 000 1048576
   ASAM Dataset: EV_ECM20TDI01104L906021BD 002005
   ROD: EV_ECM20TDI01104L906021BD_002.rod
   VCID: 68DF0DA79373D2C6A3-803C
No fault code found.
Readiness: 0 0 0 0 0
Address 02: Auto Trans (J217)       Labels:| 0CJ-927-156.clb
   Part No SW: 4G0 927 153     HW: 0CK 927 156 L
   Component: 0CK 20TDI RdW H03 0003
   Revision: --H03---    Serial number: 0000000239
   Coding: 000001
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_TCMDL382021 002011
   ROD: EV_TCMDL382021_VW51.rod
   VCID: 66C3039F9967C4B691-8032
Address 03: ABS Brakes (J104)       Labels:. 4G0-907-379-V1.clb
   Part No SW: 4G0 907 379 L    HW: 4G0 907 379 L
   Component: ESP PREMIUM   H09 0450
   Revision: --------    Serial number: --------------
   Coding: 06A29F016045F980DB00
   ASAM Dataset: EV_ESPPremiAU57X 004039
   ROD: EV_ESPPremiAU57X_004_AU57.rod
   VCID: 3A7B87EFBD5F905605-806E
Address 05: Acc/Start Auth. (J393)       Labels:. 8K0-907-064-05.clb
   Part No SW: 4H0 907 064 FN    HW: 4H0 907 064 EN
   Component: BCM2 2.0      H36 0551
   Revision: 00002001
   Coding: 01B93046000000000000
   VCID: 7AFB47EFF5DF505645-802E
   Subsystem 2 - Part No SW: 4H0 905 852 C    HW: 4H0 905 852 C
   Component: J764 ELV MLB  H40 0046
   Serial number: 0214000134358006
Address 08: Auto HVAC (J255)       Labels:| 4G0-820-043-2Z.clb
   Part No SW: 4G0 820 043 BA    HW: 4G0 820 043 BA
   Component: KLIMA 2 ZONEN H14 0096
   Serial number: 22071400111258
   Coding: 3422090821
   ASAM Dataset: EV_AirCondiBasisUDS 004002
   ROD: EV_AirCondiBasisUDS_004.rod
   VCID: 5FCD167B463D957E52-800A
Address 09: Cent. Elect. (J519)       Labels:. 4H0-907-063-V1.clb
   Part No SW: 4H0 907 063 CE    HW: 4H0 907 063 E
   Component: BCM1 2.0      H12 0130
   Revision: 19012002    Serial number: 00000001559930
   Coding: 2600201141349FE00181008000001D0CCF9DC70827090201000004606100
   VCID: 6DD17CB3B491F7EED0-8038
   Subsystem 1 - Part No SW: 4G2 955 119     HW: 4G8 955 119 A  Labels: 1KX-955-119.CLB
   Component: WWS57X 140705  H37 0080
   Serial number:         140712195521
   Coding: 0045F7
   Subsystem 2 - Part No SW: 8U0 955 559 B    HW: 8U0 955 559 B  Labels: 8U0-955-559.CLB
   Component: G397_RLFS  H06 0002
   Serial number: 22928019
   Coding: 02006D
   Subsystem 3 - Part No SW: 4G0 941 531 BE    HW: 4G0 941 531 BE
   Component: E1 - LDS  H07 0044
   Serial number: 24 07 2014  00000073
   Subsystem 4 - Part No SW: 4G0 907 658 A    HW: 4G0 907 658 A
   Component: Humidity_Sens  H03 0002
   Serial number: 0F380E37000000000001
Address 10: Park/Steer Assist (J446)       Labels:| 4H0-919-475-7X2.clb
   Part No SW: 4H0 919 475 AA    HW: 4H0 919 475 AG
   Component: PARKHILFE ACC H01 0083
   Revision: 11001001    Serial number: 61061420700194
   Coding: 08C308
   ASAM Dataset: EV_EPHVA18AU57X0000 004009
   ROD: EV_EPHVA18AU57X0000_004.rod
   VCID: 71E960C3A0A9130EF4-8024
Address 15: Airbags (J234)       Labels:* 4H0-959-655.clb
   Part No SW: 4H0 959 655 C    HW: 4H0 959 655 C
   Component: Airbag10.43   H43 0040
   Revision: --------    Serial number: 003JG00JSMV9
   Coding: 3032343631324E303235554A305234473053
   ASAM Dataset: EV_AirbaAU10BPAAU64X 001014
   ROD: EV_AirbaAU10BPAAU64X_VW51.rod
   VCID: 366393DF89477436E1-8062
   Crash sensor for side airbag: driver side:
   Serial number: 3575HRB405L2M4PGD05K
   Crash sensor for side airbag: front passenger side:
   Serial number: 3585HRB404T2M4PG9OGG
   Crash sensor for side airbag: rear: driver side:
   Serial number: 3515JRB401E52MR86HJO
   Crash sensor for side airbag: rear: passenger side:
   Serial number: 3525JRB400M52MR4K1NU
   Crash sensor for front airbag: driver side:
   Serial number: 3554VRB401I52M1AI2B8
   Crash sensor for front airbag: front passenger side:
   Serial number: 3564VRB401G52M1AE27%
Address 16: Steering wheel (J527)       Labels:. 4H0-953-568.clb
   Part No SW: 4G0 953 568 A    HW: 4G0 953 568 A
   Component: Lenks.Modul   H05 0201
   Revision: 00000000    Serial number: 20140724000292
   Coding: 000035
   VCID: 306FA5C763235A06BB-8064
   Subsystem 1 - Part No SW: 4G0 951 528 A    HW: 4G0 951 528 A
   Component: E221 - MFL  H08 0010
Address 17: Instruments (J285)       Labels:| 4H0-920-xxx-17.clb-SRI1
   Part No SW: 4G8 920 950 S    HW: 4G8 920 950 S
   Component: MDieGb        H43 0411
   Revision: 27450259    Serial number: 658220714592032
   Coding: 23A712000B412600010000
   ASAM Dataset: EV_RBC7KMID 004048
   ROD: EV_RBC7KMID.rod
   VCID: 3F8DF6FBA67DB57E32-806A
1 Fault Found:
1048578 - No Basic Setting
          B2010 00 [009] - -
          [New feature! Extended UDS fault detail is only supported by current gen. interfaces]
          Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 8
                    Mileage: 71749 km
                    Date: 2020.10.08
                    Time: 18:19:13
Address 19: CAN Gateway (J533)       Labels:* None
   Part No SW: 4G0 907 468 AD    HW: 4G0 907 468 AC
   Component: J533--Gateway H13 0050
   Revision: --------    Serial number: 00000001488916
   Coding: 00CD074400
   ASAM Dataset: EV_GatewPkoUDS 001019
   ROD: EV_GatewPkoUDS_001_AU57.rod
   VCID: 72EB6FCFA5AF28160D-8026
   Battery Monitoring Control Module:
   Subsystem 1 - Part No SW: 8T0 915 181     HW: 8T0 915 181
   Component: J367-BDMHella  H03 8041
   Serial number: 7077174103
   Voltage stabilizer:
   Subsystem 2 - Part No SW: 8K0 959 663 D    HW: 8K0 959 663
   Component: J532_DCDCStab  H23 0021
   Serial number: 14052200000000000251
1 Fault Found:
0268 - Optical data bus
          U1049 00 [008] - Open circuit
          Intermittent - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 83
                    Mileage: 72186 km
                    Date: 2020.10.25
                    Time: 19:05:22
                    Voltage terminal 30: 14.4 V
                    Voltage terminal 15: 14.5 V
                    Control Module temperature: 19 °C
                    System status: Terminal 15 on
                    IN ESP_standstill flag: standstill detected
                    Engine running: On
                    IN ZAS_Te_X: On
                    Terminal 15 status via CAN: On
                    Terminal 15 status: On
                    Datenfeld: 0
Address 3B: Sensor Elect. (J849)       Labels: 4G0-907-637.clb
   Part No SW: 4G0 907 637 H    HW: 4G0 907 637 D
   Component: SARA 3D       H03 0056
   Revision: --------    Serial number: EJ1BPA720BED75
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   VCID: 3365AACB9A35611EC6-8066
Address 42: Door Elect, Driver (J386)       Labels:. 4H0-959-793.clb
   Part No SW: 4G8 959 793 J    HW: 4G8 959 793 G
   Component: TSG FA        H03 0507
   Coding: 011F16005C01620002080002
   VCID: 479DEE1BF6ADFDBE8A-8012
Address 44: Steering Assist (J500)       Labels:| 4G0-909-144.clb
   Part No SW: 4G0 909 144 M    HW: 4G0 909 144 G
   Component: RCEPS         H41 0011
   Revision: 00001000    Serial number: 0009754862
   Coding: 101000010000
   ASAM Dataset: EV_RCEPS 009010
   ROD: EV_RCEPS_009.rod
Address 46: Central Conv. (J393)       Labels:. 4H0-907-064-46.clb
   Revision: 00002001    Serial number: 0342423548
   Coding: 013F0622A0B930808320090C00010F470000000000000000000000000000
   Subsystem 1 - Part No: 4G0 951 177
   Component: DWA-Sensor  H01 0010
   Subsystem 2 - Part No: 1K0 951 605 C
   Component: LIN BACKUP HO  H05 1501
Address 52: Door Elect, Pass. (J387)       Labels:. 4H0-959-792.clb
   Part No SW: 4G8 959 792 J    HW: 4G8 959 792 G
   Component: TSG BF        H03 0507
   Coding: 011F16005E01620002080002
   VCID: 4683E31FF1A7E4B671-8012
Address 53: Parking Brake (----)       Labels: 4H0-907-801.clb
   Part No SW: 4H0 907 801 H    HW: 4H0 907 801 A
   Component: EPB-4         H04 0015
   Revision: --------    Serial number: 00000001149941
   ASAM Dataset: EV_ParkiBrake 001028
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 2D51BCB37C1137EE90-8078
Address 55: Headlight Range (J431)       Labels:| 8X0-907-357.clb
   Part No SW: 4H0 907 357 B    HW: 4H0 907 357 B
   Component: ....LWR12.... H02 0010
   Serial number: 140725-0002-188
   Coding: 112296101000A300
   ASAM Dataset: EV_HeadlRegulBasic 005001
   ROD: EV_HeadlRegulBasic.rod
Address 5F: Information Electr. (J794)       Labels: None
   Part No SW: 4G0 035 192 R    HW: 4G0 035 192 F
   Component: RMC Nav Plus  H55 0840
   Coding: 0101010101415B47082B060301010000010000
   VCID: 3169A0C36829530EB4-8064
   Subsystem 1 - Part No: 8X0 060 884 M
   Component: P43-50-18.06  0001
   Subsystem 2 - Part No SW: 4G0 919 603 B    HW: 4G0 919 603 B
   Component: DU6 Basic  H43 0084
   Serial number: 9464G$0E2670860
   Subsystem 3 - Part No SW: 4G2 919 610 B    HW: 4G2 919 610 B
   Component: E380 BDT C7  H11 0204
   Serial number: 90349NGH000EW
2 Faults Found:
03278 - Functionality Limited due to Missing Messages
            000 - - - Intermittent
             Freeze Frame:
                    Fault Status: 00100000
                    Fault Priority: 6
                    Fault Frequency: 14
                    Reset counter: 83
                    Time Indication: 0
             Freeze Frame:
                    Bin. Bits: 01111111 11100111
                    Bin. Bits: 00000000 00000001
03276 - Please Check Software Version Management
            000 - -
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 44
                    Mileage: 72186 km
                    Time Indication: 0
                    Date: 2020.10.25
                    Time: 19:39:08
             Freeze Frame:
                    Voltage: 14.60 V
Address 62: Door, Rear Left (J388)       Labels:. 4H0-959-795.clb
   Part No SW: 4G8 959 795 J    HW: 4G8 959 795 G
   Component: TSG HL        H03 0507
   Coding: 020F14004001620002080002
   VCID: 4999E823E0B90BCE9C-801C
1 Fault Found:
01042 - Control Module; Not Coded
            000 - -
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 27
                    Mileage: 72000 km
                    Time Indication: 0
                    Date: 2020.10.18
                    Time: 19:34:14
Address 6D: Trunk Elect. (----)       Labels:* Redir Fail!
   Part No SW: 4G9 959 107 B    HW: 4G9 959 107 A
   Component: HDSG-Modul    H03 0143
   Revision: 14003001    Serial number: 198400752
   Coding: 097205C010
   ASAM Dataset: EV_HDSGAu572 001022
   ROD: EV_HDSGAu571.rod
   VCID: 356194D394417F2EE8-8060
Address 72: Door, Rear Right (J389)       Labels:. 4H0-959-795.clb
   Component: TSG HR        H03 0507
1 Fault Found:
            000 - -
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 27
                    Mileage: 72000 km
                    Time Indication: 0
                    Date: 2020.10.18
                    Time: 19:35:54
Address AC: Reductant Control (J880)       Labels: 4G0-907-355.clb
   Part No SW: 4G0 907 355 C    HW: 4G0 907 355 B
   Component: SCR-Stg-G2    H10 0010
   Revision: 00000000    Serial number: 141920775
   ASAM Dataset: EV_RDCMA00100 008040
   ROD: EV_RDCMA00100.rod
   VCID: 2B55B2AB420539DE8E-807E
End-------------------------(Elapsed Time: 04:51)--------------------------
Saturday,31,October,2020,14:54:19:00009
www.Ross-Tech.com
          6D 72 AC
19-CAN Gateway -- Status: OK 0000
   Revision: 85H23---
   Coding: 000001
   Revision: 00002001
   Coding: 3422090821
   Coding: 0045F7
   Coding: 02006D
   Coding: 08C308
   Coding: 000035
1 Fault Found:
          B2010 00 [009] - -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 55
                    Mileage: 72302 km
                    Date: 2020.10.31
                    Time: 14:34:18
   Coding: 00CD074400
   Voltage stabilizer:
   ROD: EV_SARA2.rod
1 Fault Found:
            000 - -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 55
                    Mileage: 72302 km
                    Time Indication: 0
                    Date: 2020.10.31
                    Time: 14:43:10
             Freeze Frame:
                    Voltage: 11.90 V
1 Fault Found:
            000 - -
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 27
                    Mileage: 72000 km
                    Time Indication: 0
                    Date: 2020.10.18
                    Time: 19:34:14
   Coding: 097205C010
1 Fault Found:
            000 - -
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 27
                    Mileage: 72000 km
                    Time Indication: 0
                    Date: 2020.10.18
                    Time: 19:35:54
End-------------------------(Elapsed Time: 04:32)--------------------------
