Adaptacja s tronic
Walek23
- Imię: Piotr
- Rocznik: 2013
- Moje auto: Inne
- Silnik: 3.0 TFSI CCAA 299KM
- Napęd: 4WD
Adaptacja s tronic
Witam! Jest osoba na forum która potrafi zrobić adaptacje skrzyni DL501 0B5 s tronic? Pozdrawiam
predki
- Imię: predki
- Silnik: 3.0 TDI 233KM
Re: Adaptacja s tronic
7-Speed S-Tronic Direct-Shift Gearbox (DSG/0B5)
Prerequisites:
Transmission fluid level correct
Transmission fluid temperature between 40°C - 100°C. (one user reports this needs to be below 60°C)
TCM fault free however it is strongly recommended to check/clear all Powertrain controllers faults also.
Key on, Engine off
Selector lever in P
All 3 Basic Setting operations need to be completed in the order listed below
[Select]
[02 - Auto Trans]
[Basic Settings - 04]
Select Erase counter for start and stop processes
[Go!] to activate the Basic Setting.
After the result of Finished Correctly or Not Running appears click [Stop]
[Done, Go Back]
Start the Engine and leave the Selector lever in Park
Select Clutch valve calibration [Go!] to activate the Basic Setting.
After the result of Finished Correctly appears click [Stop]
Select Distance sensor calibration
Clunking noises from the transmission are normal
[Done, Go Back]
Switch off Ignition, wait 10 Seconds and switch it back on.
[Fault Codes - 02]
Check and clear any fault codes
[Close Controller, Go Back - 06]
Perform a test drive and check for fault codes again after doing so.
Prerequisites:
Key on, Engine off
Selector lever in P
[Select]
[02 - Auto Trans]
[Done, Go Back]
[Done, Go Back]
[Fault Codes - 02]
Było Audi80 b2 2.0 litra PB
Było Audi80 b3 1,8 litra PB
Było Audi80 b3 1,9 litra PB
Było Audi a4 b5 1,9 litra ON
Było Audi a4 b6 1,8T litra PB
było Audi a6 c6 2,4 pb
