[a6 c6]jak sprawdzic czy jest fbas
: 25 wrz 2010, 00:57
autor: Modrzej
wiem ze juz bylo ale jak szukam to teraz niemoge tego odszukac jak sprawdzic vcds czy mam odpowiedni interface z fbasem i po drugie jakie modele sa z fbasem a moze to pomoze wam okreslic czy mam interface z wejsciem fbas bo nieposiadam tv tunera
Address 01: Engine Labels: 03G-906-016-BLB.lbl
Part No SW: 03G 906 016 HS HW: 03G 906 016 HS
Component: R4 2,0L EDC G000SG 8754
Revision: --H02--- Serial number:
Coding: 0000072
Shop #: WSC 02324 785 00200
No fault code found.
Readiness: 0 0 1 1 1
Address 03: ABS Brakes Labels: 4F0-910-517.lbl
Part No SW: 4F0 910 517 AC HW: 4F0 614 517 T
Component: ESP8 front H01 0070
Revision: 00000000 Serial number: 00000000000000
Coding: 0020855
Shop #: WSC 02325 785 00200
Address 05: Acc/Start Auth. Labels: 4F0-910-852.lbl
Part No SW: 4F0 910 852 HW: 4F0 905 852 B
Component: FBSAUDIC6 ELV H31 0220
Revision: 31050601 Serial number: 10601000495291
Coding: 0000017
Shop #: WSC 02323 785 00200
Part No: 4F0 910 131 D
Component: FBSAUDIC6 EZS H45 0080
Part No: 4F0 910 220 D
Component: FBSAUDIC6 IDG H01 0040
Address 07: Control Head Labels: 4F0-910-7xx-07-H.lbl
Part No SW: 4F0 910 732 S HW: 4E0 035 729
Component: Interfacebox H43 5150
Revision: 00000000 Serial number: 350GZ067708668
Coding: 0000302
Shop #: WSC 00000 000 00000
Part No: 4F0 910 609 E
Component: Bedienteil MMIC6H02 0060
Address 08: Auto HVAC Labels: 4F0-910-043.lbl
Part No SW: 4F0 910 043 HW: 4F2 820 043 M
Component: KLIMABETAETIGUNGH20 0170
Revision: 00000031 Serial number: 00000030150040
Coding: 0001044
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 K HW: 4F0 907 279
Component: ILM Fahrer H17 0240
Revision: 00000000 Serial number: 4F0907279
Coding: 0001101
Shop #: WSC 02335 785 00200
Part No: 4F2 910 113 A
Component: Wischer AudiC6 H04 0190
Coding: 00064784
Shop #: WSC 02335
Part No: 4E0 910 557 A
Component: REGENLICHTSENSORH13 0090
Coding: 00146221
Shop #: WSC 02335
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 111 F HW: 4E0 035 111 A
Component: CD-Changer H44 0470
Revision: 00000000 Serial number: AUZ5ZBF8168940
Address 15: Airbags Labels: 4F0-910-655-8R.lbl
Part No SW: 4F0 910 655 E HW: 4F0 959 655 B
Component: 4E AIRBAG AUDI8RH29 0280
Revision: 08H29000 Serial number: 0037LD0G2ELB
Coding: 0013381
Address 16: Steering wheel Labels: 4F0-910-549.lbl
Part No SW: 4F0 910 549 HW: 4F0 953 549 A
Component: Lenksäulenmodul H08 0230
Revision: 00H08000 Serial number: 90055062010098
Coding: 0102041
Part No: XXXXXXXXXXX
Component: Lenkradmodul H07 0090
Address 17: Instruments Labels: 4F0-910-xxx-17.lbl
Part No SW: 4F0 910 930 C HW: 4F0 920 981 F
Component: KOMBIINSTR. M73 H18 0110
Revision: 00300000 Serial number: 5HS32FL76
Coding: 2308143
Shop #: WSC 00497 210 88415
Address 19: CAN Gateway Labels: 4F0-910-468.lbl
Part No SW: 4F0 910 468 A HW: 4F0 907 468 D
Component: Gateway H11 0070
Revision: 11 Serial number: 13008067228027
Coding: ECEE53C41B3104
Shop #: WSC 02334 785 00200
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 P HW: 4E0 919 887 D
Component: MNS ECE H48 1060
Revision: 00000000 Serial number: 364GS067583151
Shop #: WSC 00149 210 85453
Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
Part No SW: 4F0 910 793 E HW: 4F0 959 793 E
Component: TSG FA H12 0120
Revision: 00000000 Serial number: ™aƒ
Coding: 0002586
Shop #: WSC 02327 785 00200
Address 46: Central Conv. Labels: 4F0-910-289.lbl
Part No SW: 4F0 910 289 G HW: 4F0 907 289 G
Component: Komfortgeraet H22 0170
Revision: 01700022 Serial number: 01017047960000
Coding: 0000251
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Part No: 4F0 910 177
Component: Innenraumueberw.H01 0020
Address 47: Sound System Labels: 4F0-910-223-BO.lbl
Part No SW: 4F0 910 223 J HW: 4F0 035 223 G
Component: DSP-High C6 H09 0240
Revision: PROD_01 Serial number: 00000000011225
Coding: 0000013
Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
Part No SW: 4F0 910 280 HW: 4F0 907 280 A
Component: ILM Beifahrer H10 0080
Revision: Serial number: 00000000268556
Coding: 0001104
Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
Part No SW: 4F0 910 793 E HW: 4F0 959 792 E
Component: TSG BF H12 0120
Revision: 00000000 Serial number: ‘„
Coding: 0002586
Address 53: Parking Brake Labels: 4F0-910-801.lbl
Part No SW: 4F0 910 801 B HW: 4F0 907 801 A
Component: EPB CB4C0060 H04 0060
Revision: --H04---
Coding: 0000111
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 T HW: 4F0 035 541 H
Component: TUNER EU/US/RDW H42 0630
Revision: 00000000 Serial number: 394GW067670713
Coding: 0000001
Address 61: Battery Regul. Labels: 4F0-910-181.lbl
Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
Component: J0644 BEM H12 0590
Revision: 00000000 Serial number: 00000000076487
Shop #: WSC 00751 210 08354
Part No: 4F0 915 105 D
Component: von VA0 2607280620
Coding: 344630393135313035442056413032363037323830363230
Shop #: WSC 00000 384 00290
Address 62: Door, Rear Left Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 E HW: 4F0 959 795 E
Component: TSG HL H21 0050
Coding: 0002050
Address 72: Door, Rear Right Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 E HW: 4F0 959 794 E
Component: TSG HR H21 0050
Coding: 0002050
Address 76: Park Assist Labels: 4Fx-910-283.lbl
Part No SW: 4F0 910 283 F HW: 4F0 919 283 F
Component: Parkhilfe 4-Kan H09 0060
Revision: 00H09000 Serial number: 06220620100802
Coding: 0000106
Shop #: WSC 131071 1023 2097151
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4E0 910 336 M HW: 4E0 862 335
Component: Handyvorb2 H13 1130
Revision: 00000000 Serial number: 00000007562330
Coding: 0010920
: 25 wrz 2010, 23:09
autor: tmr
nie masz fbas :roll:
: 25 wrz 2010, 23:37
autor: Modrzej
dzieki
[ Dodano: 2010-09-26, 00:14 ]
a czy jest mozliwosc dolozenia fbas bez wymiany interfejsu bo np dension 500 posiada fbas ale po podlaczeniu do niego avr i dvd to jeden gosciu powiedzial mi ze w audi i tak niebedzie obrazu bo ma taki system natomiast w mercedesie porsche bmw bedzie ten system dzialal prosze o wskazuwki jak uruchomic video bo nieposiadam fbas a interfejs chcialbym w miare mozliwosci zostawic ten co jest
: 16 sie 2012, 14:00
autor: UneeK
Zajrzyj tutaj LINK , zadzwoń i pogadaj, powinni Ci pomóc. Mam Densiona, DVD i kamerkę cofania zrobioną na ich BOX'ach.
